Cross Correlation vi. How does it work
How does the cross correlation vi. Work?  Is there an effect of amplitude? For example if I have a reference signal that i am passing through as my X That is identical for all correlations but my amplitude on y varies. The signals are similar in shape, so they should be ideal candidates for correlation. I am finding thorough experiments that as my amplitude on y changes so do my results. Why is this and is there a way in software to fix this or do i have to have someone man the controls.
Mark Mutton
Electrical Engineer
(3,443 Views)
Mark,
The help for the Cross Correlation.vi shows the formula as: R(t) = Integral(x(tau)*y(t+tau)*dt)
Thus, the value is sensitive to the amplitudes.
To get around variations in the y amplitudes, normalize the y array to +/-1 before sending it to the correlation VI.
Lynn
(3,439 Views)
