Cross-compiling for other platforms
My first few attempts to build a standalone application (LabVIEW 2010 / Mac) have ended in failure (lack of write permissions). A build directory gets made, all the dependent VIs are imported and the build goes on for a long time, but at the last moment, it fails with a permissions problem. My drivers are installed in the /Applications folder and are (presumably) owned by root. The build directory is owned by me. Any ideas where I should start looking ?
Further, I want to deploy this application for a few Windows users who do not have LabVIEW. How does one cross-compile ?
Message 1 of 10
(5,720 Views)
Can't help you with the first.
As for the second, you cannot cross-compile. You'd need the Windows version installed on a Windows OS and you'd need to recompile on there.
Message 2 of 10
(5,718 Views)
Thanks for the response.
Makes the application builder pretty useless then.
Message 3 of 10
(5,698 Views)
Based on what? Would you say the same thing about, say, Microsoft's compilers? Which can't create an application for Macs. Or Linux machines?
Message 4 of 10
(5,696 Views)
A few points:
Microsoft's compilers (taking Visual C++ for instance) make no pretensions about being cross-platform applications (such as LabVIEW).
Linux/Mac gcc have been cross-compilers for about as long as I can remember.
A feature like application builder should logically contain (since LabVIEW is a cross platform product) methods for a developer to compile for other platforms. The code is totally portable. The generated application can't be targetted to be portable. Seems like a lacuna to me.
Followup question - can I use the evaluation version for windows to generate the application ? I could use a virtual machine running XP.
Message 5 of 10
(5,667 Views)
The evaluation version will create an executable, but it will have a watermark on the front panel.
Message 6 of 10
(5,661 Views)
Ok. Other than the watermark, will the executable be limited in any way ?
Message 7 of 10
(5,595 Views)
Not as far as the built application it shouldn't. The Application Builder does not allow use of "Additional Exclusions" in the evaluation version. You can read more here: Limitations of the LabVIEW Evaluation Version.
Message 8 of 10
(5,588 Views)
Agree that it would be really handy if a cross-platformish LabVIEW also would compile (and pack) projects for Mac and Linux. I'm developing for all kinds of customers, regardless of their OS preferences. Anyone NI-staff or responsible or in power who would like to comment on that?
/Joshua
Message 9 of 10
(5,484 Views)
You should post this to the LabVIEW Idea Exchange. And remember, the compiler is not the app builder. The compiler is the development environment.
Message 10 of 10
(5,476 Views)
