Crush test acceleration
I am using the PXI-6224 board to acquire voltage readings in a crush test. I want to ask what is the best way to convert voltage to acceleration in labview. Is there any example anywhere?
Cheers.
Message 1 of 9
(4,688 Views)
What is the relationship between voltage and acceleration?
Voltage is an electrical value.  It could mean one of a thousand things depending on the type of sensor you are using.
Message 2 of 9
(4,655 Views)
Easy way: Look up the conversion factor in the spec-sheet or even better in the calibration sheet of the accelerometer and use the math vis to convert the voltage readings into acceleration readings.
If your crush test  involve higher frequencies than about half the resonace of the accelerometer and you want to get better than 10% a model of the sensor with its parameters and  a matched  IIR compemsation filter  would be the way to go 😉
Greetings from Germany
Henrik
LV since v3.1
Message 3 of 9
(4,639 Views)
RavensFan : I know that the voltage is proportional to acceleration.
How to convert velocity is what I am more interested on. V = Vo + at.. Voltage is converted into acceleration and adds previous velocity with current acceleration multiplied by the sample rate.
Volkers: How can I find the math VI?
Cheers.
Message 4 of 9
(4,611 Views)
Why can't you provide the sensor make and model along with the spec sheet? Why can't you find the Math functions? They are add, multiply, divide, etc. Pretty basic LabVIEW knowledge.
Message 5 of 9
(4,582 Views)
 If you need velocity the math vi INTEGRATION will help.  Or you use the Sound and vibration toolkit to convert your signals.
By taking a LabVIEW training/(online) tutorial, ... using the HELP function of the LabVIEW IDE???
Cheers.
Henrik
LV since v3.1
Message 6 of 9
(4,569 Views)
  • Its a piezoelectric sensor with 10 mv/g output and +/- 500 g dynamic range.
Message 7 of 9
(4,552 Views)
Well then that's easy.  Measure the voltage and divide by 0.01 your answer is in acceleration (Gravities normal to Earth)
Message 8 of 9
(4,546 Views)
Cheers., I am going to try it.
Message 9 of 9
(4,535 Views)
