Csv to string arrays
@GerdW wrote:
Is there a way to import the csv in string format?
Yes: read the csv file as ordinary text file…
If you actually dig into the Read Delimited Spreadsheet.vi, you will see that it is already doing a Read Text File and a Spreadsheet String To Array.  So I would not worry about that.
Message 11 of 12
(1,074 Views)
You should try this method. I think you'll get what you need.
Correct me if I'm wrong.
Kudos are welcome.
Best Regards,
Prince Agarwal,
Certified LabVIEW Developer
Message 12 of 12
(1,070 Views)
