Ctl problems! Help
I have two controls that I have created. Both are inserted into different arrays. I.E. Control 1 in one array and control 2 in the other array. On the front Panel after clicking run, I can enter data into the second array but not the first. Why is this. They are identical. Used the same way and all I get on the first array is the little hand selection. The control for both is a control and the array is a control that they are inserted into. Why is the problem? Thanks in advance for any help.
Message 1 of 9
(4,888 Views)
Im not sure that I understand exactly what you are explaining, could you please attach an example vi so that I can take a look at it?
Cheers!
Message 2 of 9
(4,885 Views)
Could you post the VI showing this problem?
It sound like one of the two is a control while the other one is an indicator.
Ton
My LabVIEW Ideas
Message 3 of 9
(4,883 Views)
Attached are the ctls. The first attachement is the main ctl that has the other ctl in them. The next post has the main program where this ctl is used.
Message 4 of 9
(4,879 Views)
Here is the main vi.
Message 5 of 9
(4,878 Views)
You still have a lot missing from your code.  Zip up your entire project and post it here.  There are several controls and subVIs still missing from your post.
Message 6 of 9
(4,872 Views)
It's impossible to figure out what is going on.  The controls you posted had embedded typedef's which you did not post.  The VI also had sub-Vi's which were not posted as well.
Message 7 of 9
(4,871 Views)
Perhaps you could write up a small vi that focuses on the problem you are having so that you dont have to include the whole project.
Cheers!
Message 8 of 9
(4,865 Views)
I just got it working. I copied the ctl that worked and changed the names. It's a huge program and I didn't want to risk it screwing up the numbered/enumerated types anywhere within the program from the array that was giving me problems. Since I named everything the same, it seems to not have effected anything. Thanks for the help anyway.
Message 9 of 9
(4,858 Views)
