CtlRef information
Can I get, programmatically, CtlRef information (Class name, Control label ,ecc.) in an event structure, so as it is displayed with the probe ?
Thanks a lot at all.
(6,603 Views)
You can use the custom probe "Control refnum Probe" or create a new one from this existing one that displays the info you need...
Hope this helps,
Cyril Bouton
Active LabVIEW Developper
(6,596 Views)
Hi, Cyril
thanks a lot for your answer,
but I intend to manage programmatically these information and not to display them.
(6,594 Views)
Sorry,
I misunderstood your question..silly me :).
Just wire a property node to the ctrl ref you got from the event structure. This will give you access to what you are looking for, exactly like the custom probes do in fact...So you can reuse part of my previous post at least, by checking out the code in the custom probe..:).
Here's an example of what I am talking about.
Cyril Bouton
(6,589 Views)
Fantastic.
Thanks a lot.
(6,584 Views)
