'Ctrl-]' Telnet Connection
How is it possible to send a break signal 'Ctrl-]' to the TELNET.vi and/or to the HyperTerm ?
(3,006 Views)
CTL-J is just the line feed character. There is a constant for this in the string palette. If yu want to include it in a string control or constant, right click on the control constant and change to '\' Codes Display and send \n or select Hex Display and send hex 0A.
(3,002 Views)
Thanks Dennis,
I meant " Ctrl + ] "   ( group separator) and not " Ctrl + J " as you thought.
Can you give me an answer to this problem.
Thank in advance,
Koby
(2,985 Views)
I guess I need a new pair of glasses. CTL + ] is hex 1D. To send it as a '\' code, you send '\1D'. If you are going to be doing much of this, you should search google for an ASCII code table. All of this would be in one.
(2,972 Views)
