Ctrl command
i want to send command Ctrl +W using labview on serial port. how can i use it? When i am sending this command on hyperterminal it gives me responce
please help me
falgandha
(2,845 Views)
Hai,
What is the syntax that the target device expects...e.g. ascii(Ctrl)ascii(+)ascii(W)<carraige return> .  Some device expects hex equivalents. So first look out for how the target device accepts the values from COM port.
This can be obained from the  manual.  If it is not available use a serial spy (HDD serial spy is best-its freeware) to determine how the hyperterminal communicates with the target device and then frame your command.
Feel free to post your queries....
With best regards,
JK
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,839 Views)
