Ctrl + . (period) doesn't seem to be working (and aborting my VI).
I checked this KB already.
Attaching trimmed VI (saved in 2017).
Could find where is the mistake or is it a bug?
Message 1 of 8
(2,541 Views)
Hi scofield,
why do you need to password-protect your VI?
Do you think this helps in debugging your VI?
Your VI just contains an event structure, waiting for a panel close event.
And it stops when I press <Ctrl + .> !
Message 2 of 8
(2,532 Views)
My bad about password protection, it was not intended.
Attached is the code with password removed.
At my end <Ctrl + .> is not working at all.
I also opened 'on screen keyboard' and tried that just to be sure that its not because of keyboard settings, but no luck.
Message 3 of 8
(2,527 Views)
Unfortunately CTRL+. works just fine to stop that VI for me so I can't reproduce your issue. Go into your options and confirm that the shortcut hasn't been messed with.
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 4 of 8
(2,493 Views)
Thank you Andrew.
I just realized that its because of 'runtime menu' (.rtm file).
Actually this VI has an associated runtime menu and when I shared the VI, I never included the RTM file.
On my end, if I remove the custom runtime menu then I'm also able to use <Ctrl + .>
Message 5 of 8
(2,456 Views)
Anybody knows about this, why the <Ctrl + .> shortcut doesn't abort a running VI with a custom runtime menu?
Message 6 of 8
(2,377 Views)
Accepted by topic author scofield
Same deal I would say... go to Edit -> Run-Time Menu... and make sure this is there:
Redhawk
Message 7 of 8
(2,371 Views)
Since typing in <CTRL + .> is a shortcut to the Operate>>Stop command in the menu, I think it would make sense that removing it from the menu would disable <CTRL + .>. That way, you can choose to prevent users from exiting the VI through that keyboard shortcut. Otherwise, the user would always have a way to interrupt the VI.
As @FireFist-RedHawk says, if you want that option available, you can include it in your custom menu.
-joeorbob
Message 8 of 8
(2,365 Views)
