Curious on how to configure axes of 3D graph
Hello, I have made a 3D graph and don't quite know how to make the axes look how I want. I have relative intensity on the Z-axis which is fine.
I have time on y-axis, which ranges from 0-500 because that is how many datapoints I have. I would like it to reflect the time the measurement was taken over (0-2ms in this case, but will change based upon a control).
I have wavelength on the x-axis ranging from 0-5 because that is how many different wavelengths I used. I would like it to read 500nm-550nm (which can both change based on controls).
If you can simply explain how to format the graph and what features I am looking for to make the axes read what I want, that would be great, thanks!
(2,827 Views)
If that
was implemented using a CW 3D graph then right-click and choose "CWGraph3D >>> Properties
and then go to the axis tab.
Ben
Message Edited by Ben on 06-14-2010 02:23 PM
(2,808 Views)
When doing that, the graph thinks that I want to change the min and max and read different data points I think. I would like to change the offset and interval.
(2,806 Views)
If the CWGraph3D option is not in your list, the above does not apply to your graph so please ignore.
Ben
(2,796 Views)
