Current Font in Labview
I have a minor, but annoying problem. I've recently done some UI work and I used a font other than "application" font. Now, anything I do defaults back to that font. No matter how many times I change the font back to "application" font, it defaults back to the font I used that one time.
How do I get the font to default to "application" font? It seems like labview always reverts to "current" font which for some reason is stuck on that font I used.
Message 1 of 8
(10,004 Views)
Accepted by topic author thutch79
Toos>>Options
Then restart LabVIEW to get the ini file uncorrupted.
EDIT: And JB's advice too.  I forgot about those!
Message 2 of 8
(9,995 Views)
  • Ctrl+0 (zero) to open the Font Dialog box
  • Select the desired font
  • Check "Panel Default" and "Diagram default"
Message 3 of 8
(9,994 Views)
You can also edit below keys of LabVIEW.ini :
appFont --> application
FPFont --> front panel
BDFont --> block diagram
The format is "Name" Size. For example :
FPFont="Tahoma" 13
Message 4 of 8
(9,988 Views)
Thanks guys. I tried Jeff's suggestion first and that seemed to do the trick.
Message 5 of 8
(9,973 Views)
I have a question on this similar topic. I have a build that the font size get's large when I put it on the end system. Both OS are Win7, I have the default for the app, diag, and system fonts check. Also, I defined in the .ini file that font and size I wanted. Any ideas? I'm using 13pt MS Sans Serif font.
Thank you for any help you can provide.
Message 6 of 8
(9,207 Views)
The Windows scaling affects the font. If you don't use AppFont, but set the text to Segoe UI 15 i think it's fixed.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 8
(9,204 Views)
Also, I'm running LV 2012sp1.
So, when you use appfont and select "Use default" is it using the computers default or what's in the .ini file?
Message 8 of 8
(9,193 Views)
