Current Measurement PXI 4065
I have a PXI 4065 under LV 8.5.1.
When a make a current measurement without the circuit under test the DMM measures 1mA. i don't know how this is possible or if this is normal.
This affects me beacause i have a circuit under test where the spected measurement is around 1mA so i don't know if the DMM acquired the correct measurement.
Any ideas? Regards
(3,531 Views)
Hi ethan85,
Thanks for the forum post and I hope your well today.
I noticed your post has been left unanswered for a few days now.
For example, if we left the input to a DAQ device and did a voltage reading, the value will float - and sometimes this can be noise or sometimes it can rail up/down to the range specified for the task.
What is the range for your task set too?
I guess the best way to see if this value is ok, is to test your device using a high current, and see if it still returns to 1mA.
Also with DAQ devices they make current measurements by measuring the voltage across a shunt resistor. This could well be the cause of the 1mA.
My last thought, is its usually not advisable to leave an input floating - so maybe some forum of pull down resistor could be used when the device DUT isn't connected.
Please let me know what you think,
Kind Regards,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,495 Views)
Hi Hillman
Thanks for your response.
I corrected this problem, I modified the range from 0.5A to 0.1A and the measurement on the floating point was of 0.17mA so this works for me.
I'll work in a application for dynamically changing the range of the DMM.
Regards
(3,486 Views)
hi!
Thanks for the update.
Im glad it works fine now - and glad that my advice would have got their in the end ! 😄
Best of luck with your application.
Kind regards,
Kind Regards
James Hillman
(3,482 Views)
