Current probes integration with DAQ
I need to do continuous current measurement of up to 40A using Tektronix TCP305A AC/DC current probes. What DAQ can I use for this purpose?
(671 Views)
If those probes have just a BNC signal output, any NI DAQ with sufficient sampling rate and voltage ranges should work.
Santhosh
Soliton Technologies
(656 Views)
Understand that you will still need to use the TCPA300 Amplifier with the TCP305A Probe.
But you should be able to be measure the scaled voltage output of the amplifier with any NI-DAQ device.
So it comes down to the measurement speed and accuracy you require.
=== Engineer Ambiguously ===
(647 Views)
