03-05-2004 09:56 AM
03-06-2004 03:18 PM
03-07-2004
06:49 AM
- last edited on
12-11-2024
02:01 PM
by
Content Cleaner
OK now I will guess,
It sounds like the issue is either the chart and how you are using it OR the time on your system is off.
The example I have included should properly plot the time of readings. In it I have used waveform data types to specify the times of the readings being plotted. The waveform data type is pretty cool once you get used to using it.
The other possibility comes from you refering to a "Real-Time.VI". If you are targeting this app at RT then the time ofn your RT node may be off! If I remeber correctly, the RT targets keep their time in GMT by default.
If this is RT related I suggest follow-up Q's be posted to the LV-RT group.
I hope this help,
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
