Current vs time using Keithley 2400
I am using Keithley 2400 and Labview 2010. I want to source voltage and measure current for every t secs until say 300 secs. How can I do that? Can anyone provide a Labview program that can run in 2010 version without any errors?
Thanks for your help!
(4,210 Views)
Start with one of the examples such as Keithley 24XX Read Single. Place a loop around the Read function and wire the results to a chart. Place a Time Delay function inside the loop with a control to set the wait. Use this time to set the XScale.Multiplier property node (like Real Time Chart example). An Elapsed Time function can be used to terminate the loop.
(4,203 Views)
