Cursor Value from Tek DPO7000
I am using Labview to do some data acquisition from Tek DPO7000 oscilloscope. I have setup the cursor on the scope manually and need to use Labview to store the cursor value in a file. I am not able to find a way of reading the cursor value in Labview. The type of the cursor is "Waveform" and its x axis will remain fixed throughout the measurement.
(2,462 Views)
Hi LV_Max,
To be able to use the oscilloscope, you will need to download the instrument drivers from here.
Then you will copy the files to the inst.lib in yout LabVIEW installation folder and under the Instrument I/O you will find the available options for the tasks that you can do with that oscilloscope.
steve.bm
AE | NI
(2,440 Views)
