Cursor crosses curve in 2 points: find 2nd point
Here is emulation of a part of my mesuerement setup.
Here are keypoints:
  • measurement curve (emulated by sinc function)
  • 2 free cursors TOP and BOTTOM
  • 1 locked cursor "MIDDLE": its Y is calculated as mean value of TOP and BOTTOM
  • 1 crossing point can be derived from Active Cursor property (PosX and PosY)
Does exist a simple way to find 2nd crossing point.
Thanks in advance
(4,777 Views)
Here is a solution which is a little bit tricky.
It works as follows:
  1. On cursor release (TOP or BOTTOM) the mean value of Y is calculated
  2. Cursor MIDDLE (locked to the curve) is set
  3. Coordinate X of the cursor MIDDLE is derived
  4. Index of the coordinate X is found in the original array
  5. Original arrays X and Y is cut next to X coordinate index
  6. New curve is built on supplementary graph "XY graph 2"
  7. Coordinate X of the cursor on supplementary graph is found
  8. Coordinate (X1, Y) and (X2, Y) are applied to Annotation List collection
The probelem here is when I hide "XY graph 2", the method isn't stable - sometimes original curve is cut correctly, sometimes - NOT.
Any comments ?
(4,756 Views)
Here is approach (still a bit complicated) that works:
(4,737 Views)
this here would get more than two crossings
(4,724 Views)
Accepted by topic author Pavel_47
Ok, sorry for hijacking this thread, case "all" was quite easy:
0# all:
getting the first x-position wasn't too bad
first:
getting the last x-position of a crossing was slighty harder but feasible without queues:
last:
....but getting the middle was quite tough, is there an alternative besides using queues ?
median:
Alex
(4,709 Views)
Hello Alex,
Your approach is quite ingenious. Congratulations !
Especially I liked "median" case, actually it's what I need.
(4,684 Views)
@Pavel_47 wrote:
Hello Alex,
you are welcome 🙂
This version of the median case mighty be a bit more comprehensible:
Alex
(4,662 Views)
