Cursor in a specific text box
I would like to know how to automatically set the cursor in a specific textbox (in the front panel) when my window is loaded.
I tried with the keybinding control (home for example) so if I type home key it goes there but I want this cursor in this specific textbox without typing anything.
Thank you in advance.
Sebastien
(3,337 Views)
Use the KeyFocus property for the control. Right-click on the control, select Create->Property Node->Key Focus. Change it to write and wire a "True" Boolean constant. Do this at the start of the program.
(3,331 Views)
Thank you, I have tried and it works.
(3,306 Views)
