Cursor legend automatically resize
I have a VI, and the VI front panel has a waveform control 。I sets the VI front panel pane to scale all objects according to the size of the pane.In practice, when the front panel is resized, the size of the drawing area of the waveform will be scaled, but the cursor legend size of the waveform will not be scaled.Is there a way to scale the cursor legend along with the front panel size?
(3,123 Views)
"Is there a way to scale the cursor legend along with the front panel size?"
I do not think so.
All of the attributes of the cursor can be set via property nodes so...
You could hide the built-in cursor legend create your own, put it in a sub-panel in a separate pane and react to the resize event...
If you really want that.
Ben
(3,029 Views)
