Cursor methods
How do I access a specific value on a waveform graph, which is made from a signal input, so that I can use values on the graph in calculations? It does not necessarily need to use cursor, I just want to access a value on the graph.
(3,559 Views)
You can use a mouse-down events and translate the pixel coordinates to graph values.
(3,549 Views)
How would I go about doing that?
(3,546 Views)
Personally, I have found cursors to be easier because you can lock the cursor to a specific plot, and events let you see when the cursor(s) are moved.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,534 Views)
It is pretty simple. Use an event case structure. Choose mouse down event. You will directly get x y coordinates
(3,530 Views)
