Cursor position in Image indicator
Hello everybody
I have a problem with retreiving the cursor position in an image indicator. The position of the cursor is displayed under the indicator but I can not find a way of extracting the information.
I'am using LV 7.0 with vision toolkit.
Can anybody point me in the right direction?
/Jaan
(4,097 Views)
Hi Jaako,
Create a property node for the image indecator. and take the clustar of cursor information.
I made you a small VI demonstrates this.
good luck
Tareq
(4,089 Views)
Hi again,
Last VI was on LV 7.1
Here is the ver.7 VI
(4,087 Views)
Hello Tareq
Thank you for your help The example you supplied does not work for me, when I pop up on the property node there is no Last mouse position property and the VI is not executable (it has a broken wire between the property node and the indicator). It seems that this is a feature added in LV7.1?
Is there another way of getting the cursor position?
/Jaan
(4,078 Views)
Sorry for that, but I will describe what to do:
First right click on the image indicator on the block diagram>>create>>property node
left click the property node and select from the drop down menu "last mouse position">>all elements
if you didnt find it, I'm afraid it would be a 7.1 feature
I will install ver. 7 and find out.
sorry again
(4,075 Views)
