Cursor values manipulation in "Mixed Graph"
I have two cursors on the "Mixed graph".
Using Cursor Palette, I am reading the current values of both cursors. But when I manipulate them, it works only when the program is running. Is there any way to find the difference between the two even when the program is not running.
Secondly, when I try to find the x-value using property node, it gives X- value of 2nd cursor only. how can I extract the X-value of 1st Cursor.
(2,461 Views)
Billo000,
Here are some examples on using Mixed Graphs and the cursor palette:
https://decibel.ni.com/content/docs/DOC-3671
https://decibel.ni.com/content/docs/DOC-2065
https://decibel.ni.com/content/docs/DOC-2171
https://decibel.ni.com/content/docs/DOC-3118
I hope these get you going 🙂
Sam S
(2,454 Views)
