Cursors on 3D Graph
I am new to Labview and I would like to know if it is possible to setup 3D graph cursors to show only the zone where they are crossing. For exemple let's say I have 8 XYZ cursors the cursor's dots would create a rectangle and I would like for whatever part of the cursor line which is outside of the said rectangle to do not appear on the graph.
I can see an alternative by using the cursors parameters> setup the cursors to do not be visible and plot lines between the cursors coordinates but I wish to know if there is a easier option using property nodes for exemple.
Message 1 of 1
(1,271 Views)
