Curve Fit model for Non-linear curve fit - error 23081
Dear All, I'm getting a most strange error when using the labview Non-linear curve fit Vi .
I'm using it in the form of model function. I created my model function using the template indicated in the detailed help.
However, when i run the simple test Vi which includes the fitting routine i get an error stating there is a bracket error - location unknown - error 23081.
I've attached the Vi i'm using for the fitting and also the Vi that generates the model function.
I would really welcome some help as to where the "bracket" issue is coming from, especially as i haven't used any brackets ?
Could it possibly be an old error from some earlier work that isn't being deleted ? Honestly i have no idea.
Please see attached.
All help and advice warmly welcomed.
Jon.
(3,174 Views)
solved.
there was some floating code hiding behind something on my desktop which wasn't being picked up.
oops.
(3,167 Views)
