I wanna do a curve fitting of differential equations, following is the equations:
dx/dt = u*x-a*x
ds/dt = b*u*x+c*x
dp/dt = d*u*x+e*x+f*p
and u = um*s/(km+s+s^2/ki)
I've tried "nonlinear curve fit( Lev-Mar)", but I met difficulties when writing the f(x,a) of Lev-Mar.
Then I tried "Constrained Nonlinear Optimization", I found that the example "Estimate Nonlinear Spring Constant.vi"
in the "labview\examples\math\curvefit.llb" was similar to the fitting I tried to do, but there was only one parameter
need to estimate in this example,but what I need is to estimate 3 parameters.
However,I modified the example to my equations, it failed again.
How can I achieve this? is it possible to do this fit only using Labview VIs or need Matlab Script Node?
Any help will be appreciated.
