Curve envelope
I am acquiring data using a PXI-5124 digitizer. The number of data points acquired is between 3000 to 4000.
The data is very noisy. I want to obtain envelopes of the data
as shown in the attached figure (blue curve is the acquired signal and red curves in both the pictures is the desired curve).
How do I do this in labview ?
(3,531 Views)
Check out this thread:
http://forums.ni.com/t5/LabVIEW/extract-the-envelop-of-waves/m-p/685026?requireLogin=False
You may find some useful info.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,483 Views)
