Curve fit for sensor data
1. Have a thermistor, data whose dataset is available not anything else from company except B value. Attached is data.   Resistance is "x" & temperature is "y"
Need to fit y =F(x)
2. Trying to make a equation for it and implement for 8 bit MCU, usin IAR IDE.
3. First I made this code, steinhart thermistor equation. calculated values of A,B,C from this site:  https://www.thinksrs.com/downloa...  . Put three values at -20C, 25C & 100C and get A,B,C
Its involves natural log and can fit data points, but I have to implement it on 8 bit MCU so it takes lots of space on it.
4. Then I used labview tool, to make equation , I have to break it down dataset into multiple sets for fitting 2nd order equation.
Here are coefficients for resistance values I got, for 2nd order
    if( (resistance <= 956040.0f) &&  (resistance >= 482170.0f) )
        c0 = 14.5029518320319131f;
        c1 = -0.000057344817030149406f;
        c2 = 0.000000000021788855747503695f;
    else if(resistance >= 250140.0f)
        c0 = 29.3136847463533279f;
        c1 = -0.000119496884518122221f;
        c2 = 0.0000000000876747221220605721f;
    else if(resistance >= 130230.0f)
        c0 = 45.3985586636038647f;
        c1 = -0.000249401966454676711f;
        c2 = 0.000000000352768556658954028f;
    else if(resistance >= 71230.0f)
        c0 = 62.1448935476119572f;
        c1 = -0.000506560472110208432f;
        c2 = 0.00000000135019658772898851f;
    else if(resistance >= 39200.0f)
        c0 = 79.7753263268828902f;
        c1 = -0.00100556530593662709f;
        c2 = 0.00000000491385322365418885f;
    else if(resistance >= 21830.0f)
        c0 = 98.8979251125107339f;
        c1 = -0.00198872984475097995f;
        c2 = 0.0000000176669521860767602f;
    else if(resistance >= 12750.0f)
        c0 = 118.809289117525665f;
        c1 = -0.00381338043851388829f;
        c2 = 0.0000000598289053823529209f;
    else if(resistance >= 7327.0f)
        c0 = 140.313484336487619f;
        c1 = -0.00722784306211046376f;
        c2 = 0.000000196440993753396293f;
    else if(resistance >= 6683.0f)
        c0 = 133.215333415477943f;
        c1 = -0.00480709971651089099f;
        c2 = 0.0f;
Any other method, where I get better fit equation or lesser sub datasets I have to break to?
(4,106 Views)
Hi Vindhyachal,
with sensors like thermistors (NTC or PTC type) you often use additional resistors to form voltage dividers with the thermistor and also to linearize the voltage=f(temperature) behaviour, as described in this AppNote.
This Appnote also shows methods to convert the voltage signal back to a temperature:
  • apply a polynomial on the linearized voltage signal
  • using a LUT in the linearized voltage signal
For the NTCs I work with I choose the linearization resistor based on (mainly) two considerations:
  • current through NTC to prevent self-heating
  • best linearization behaviour depending on the expected typical temperature range to be measured
(4,093 Views)
Here is VI I made
It keep on decreasing dataset values unless error is less than defined error. This way i can divide equation into multiple parts.
(4,087 Views)
Hi Vindhyachal,
use the data to create a LUT, then interpolate linearly between two neighboring data points (should be accurate enough for a NTC sensor):
To improve code performance you need to create the LUT only once: all the code until Reverse1DArray should only be called once. You can even create a constant of the data after Reverse1DArray…
(4,080 Views)
@gerdw can u share the VI.
Dont have much exp in coding in labview. Could nt find the image icons some of them
(4,025 Views)
Hi Vindhyachal,
@Vindhyachal.Takniki wrote:
can u share the VI.
It's a snippet. Read the LabVIEW help on "snippets"…
There are only 5 simple functions:
  • SpreadsheetStringToArray
  • IndexArray
  • Index&BundleClusterArray
  • Reverse1DArray
  • Interpolate1DArray
(4,022 Views)
