Curve fit
How can I get the errors of the non-linear coefficients from the curve fit express VI?
(5,035 Views)
Hi Miko,
Thank you for contacting National Instruments.  From what you are describing here, it looks like you are looking for more than the mean squared error that is provided in the express VI.  This is the only value that is going to be explicitly provided from this Express VI.  To get this value you can drag down the bottom of the VI to increase the number of I/O ports and click to select mean squared error.  Sorry if not having error for each non-linear coefficient is a large inconvenience for you.
I hope this helps!  Let me know if there is anything else I can help with or clarify.  Have a great day!
Jason W.
(5,009 Views)
Jason is right, your options from the Express VI are limited, but we might be able to work around this.  What precisely are you looking for?  Do you want the best fit parameters std. deviation?  Do you want the confidence intervals for the best fit parameters?  What version of LabVIEW are you using?
-Jim
(4,988 Views)
When performing a curve fitting, the parameters of the model should have their errors, and this is what I am looking for.
 I am not familiar with the term "confidence intervals" , but I think that the "best fit parameters std. deviation" can be what I am looking for.
I know that the Curve fit Express VI does not supply that but maybe you know how else can I get it?
Thanks for the help.
Miko.
(4,946 Views)
I am using LabView 8.2.
Miko.
(4,945 Views)
A discussion related to your question. Hope this helps
Chilly Charly    (aka CC)
(4,942 Views)
Thanks it was just what I needed.
Miko.
(4,881 Views)
