Curve fitting: Taking standard deviation into account
thanks...
especially for the weighting (ups Smiley Surprised)
(this particular gaussian fit is usless for me because I need mine. Even it looks very good :))
Message 11 of 17
(1,390 Views)
The weight is 1/variance, so you need to square the sdtdev. i.e. weight=(1/sd)² . (see also). Now the origin and nonlinear fit are very similar, see attached.
I don't understand why you have a big sequence structure. There is no problem with execution order.
Also most of your code is extremely convoluted. As an example, let's have a look at how you generate the origin data (see picture)
A simple autoindexing FOR loop is all that's needed (middle). You could even use an expression node, pasting the formula "as is". (I don't like that express VI at all, because you never know what it's doing unless you open the panel.)
Message 12 of 17
(1,356 Views)
Here's a "slightly" cleaned-up version. Modify as needed.
LabVIEW is parallel. Don't chop up the code with sequence structures. I would also use complex for xy graphs, simpler data structures. 😄
Message 13 of 17
(1,343 Views)
Unbelievable, thanks a lot.
I appreciate that.
And many thanks for the weighting issue as well!
(The sequence structure was only to show what I'm doing in a clear way)
Message 14 of 17
(1,333 Views)
Ha, but I found an other question.Smiley Indifferent
Now I get values for a,b,c,d. How do I get the standard deviation of them?
THANKS
Message 15 of 17
(1,327 Views)
You can get it from the covariance matrix. Start with this thread.
Message 16 of 17
(1,321 Views)
as far as I understand:
take each value of the diagonal -> take the square root and multiply with the RMSE-> std of the coefficients
at least the results look very reasonable
Message 17 of 17
(1,302 Views)
