Custom Control Resizing Problem
Hi ,
Currenly I tried to do a custom control . The custom control have an image on top of the button. I read thru the tutorial from the web and I know how to do it as well. But what I have faced a problem is, I tried to resize the button to become larger side, seems like the image inside the button didn't automatic resize it(refer to .bmp file) . I just wonder that what I have done wrong.
Btw I use labview 2009 .Also I inclue .bmp file is I tried to drag a control at one side seems like the image didn't go center with words. I want it go center with words no matter how I resize the button. Any help will be appreciated
thanks
(3,138 Views)
Look at this thread where I explain how to do this kind of thing.
http://forums.ni.com/t5/LabVIEW/Custom-Button-Nugget/m-p/1564566
Tim
GHSP
(3,108 Views)
Hi
thanks for your reply, Btw I went through the forum, look likes it apply true and false condition. How about the in decal mode? Is it when I change the size of the button, the image will not properly aligned?
(3,094 Views)
