Custom Control relies on a special font - Include it with distribution?
If you create a control that relies on a special font, does that font need to reside in the built application directory and/or <Windows/Fonts>?
I have a control that looks like a 7-segemt LED, and it relies on a "LCD" font.
Richard
Richard
(2,977 Views)
Richard,
I've been installing special fonts as windows fonts using the control panel font display in WindowsXP.  Most fonts can simply be copied to the c:\windows\fonts directory.
(2,966 Views)
Check out the following post: -
It gives the font file location, and an alternative solution
http://forums.ni.com/ni/board/message?board.id=170&message.id=78132&requireLogin=False
(2,956 Views)
COOL, I didn't know NI had a font. Thanks,
My original question concerns the need (or lack of) to include such a font on the distribution disk when you make an EXE?
Richard
(2,935 Views)
Did you follow through to the links at the bottom of the post?
There is a custom control available which obviates the need to install or manage additional fonts and presumably will be cross platform.
(2,924 Views)
