Custom Controls
I'm newbie in the labview world.
I'm developping an A/C panel and I have two questions about the control customizations.
1- I try to customize a rotator button.
If I have understood I must used the command panel to attribute a new rotator background.
Next I want to customize the pointer of the rotator. I succeeded to change the the pointer but it doesn't operate correctly.
2- I would create a pushbutton (P/B) with a custom label.
This P/B has:
 - One input to control the label.
 - One output to know the status of the P/B.
To display the label I use an indicator. But this label is above the P/B so I cannot click on it.
I would like to know if you have solutions to solve my problem.
If you have any questions don't hesitate.
Thx in advance for your time.
Best regards.
(3,005 Views)
Hi gaztean,
What you´re lookin for is not a "rotatory button" but a Knob, which returns a numeric value. This should make the customization part easier. There are pretty good tutorials if you do a youtube search for "Customizing LabVIEW Controls". Video is the best way to expplain this so I highly recomend you to take a look at the vids. I´m also adding a quick made example if you want to use it as a template. I hope this info is useful.
Cheers!
NavasMonk
National Instruments, México
ELP Support Engineer
www.ni.com/soporte
(2,924 Views)
