Custom IO Server -Periodic Shared Vaibale promble
want R&D on Custom IO Server -Periodic LabVIEW 2009. I have problem with LabVIEW example (Heat Exchanger). The problem is that the shared variable do not show values in the Distributed Manger and do not provide values after being deployed. Showing the status "Server Failure" or "No known value". (please find the example in the attachment)
(2,655 Views)
Hi SSRaza,
Have you taken a look at this resource: Running a DSC Module Application (DSC Module).  This details how you can set up the example so that it will work, including a link in the article on how to set up the custom periodic I/O server.  If the custom periodic I/O server is not set up correctly then we would see the errors of "Server Failure" or "No Known Value".
Hope this helps!
(2,642 Views)
