Custom Scale behavior with DAQ Task running
Hi to everyone, I am implementing a Polynomial Custom Scale for a sensor, but I have doubt about what happens if I change a Custom Scale and my DAQ Task is running, I suppose that the Custom scale does not change on the fly but my questions is if I have to clear the Task to apply the new custom scale or is enough with Stop the Task and Start the Task again.
I am using the DAQmx functions for the code. Thanks for your help.
(3,141 Views)
Hi AYanez!!
Thank you very much for using NI Discussion Forums!!  I found a post that deals with the same issue you are trying to solve for your application.  It seems that you have to stop the task for the new scaling properties to be applied.  Take a look into this thread:
Programmatically applying a custom scale in an active VI
Hope this helps!
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(3,114 Views)
