Custom Scale for Ion Gauge HELP
I have a Kurt J Lesker 354 ion vacuum gauge that puts out an analog 0-9v representing vacuum pressure in Torr.
I'm having trouble getting the custom scaling to work. I have been trying to use the DAQ assistant custom polynomial scale since I need logarithmic scaling.
The KJL354 manual gives the analog output (log-linear 0 to 9 Vdc,1 volt per decade)
Pressure Torr                    Voltage
    1.0E-10                               0.0
    1.0E-09                               1.0
    1.0E-08                               2.0
    1.0E-07                               3.0
    1.0E-06                               4.0
    1.0E-05                               5.0
    1.0E-04                               6.0
    1.0E-03                               7.0
    1.0E-02                               8.0
    5.0E-02                               8.698
As you can see, the highest vacuum at 1^(-10), is zero volts and every volt represents a magnitude of ten as the vacuum pressure decreases to 5^(-2)
since these are negative values inverse of the voltage, I put polynomial scale coefficients at:
 Order       Coefficient
a0                    1
+x*a1            10
+x^2*a2          9
+x^3*a3          8
+x^4*a4          7
+x^5*a5          6
+x^6*a6          5
+x^7*a7          4
+x^8*a8          3
+x^9*a9          2
+x^10*a10     1
The scale ends up upside down and representing a small range of exponents, whether I put the coefficients ascending or descending.
I have the pre-scale selected as volts. from what I understand each volt would be the coefficient of x.
Any Help would be apprecieted.
(3,672 Views)
The manual is here.  Look on page 32 of the pdf and it shows the conversion formulae.  (Hey, I'm not going to do ALL the legwork for you.)  😉
Bill
CLD
(Mid-Level minion.)
(3,659 Views)
Accepted by topic author Subquantum369
I Don't know why not?
(3,650 Views)
LOL it was more an exercise about how to go about finding information.  😉
You know, all that good stuff about teaching a man to fish, etc, etc...
Bill
CLD
(Mid-Level minion.)
(3,645 Views)
Thanks for the help!
I thought I could do it from the custom scale in DAQ Assistant, but your solution makes more sense.
(3,632 Views)
I don't even want to think about how many times I overcomplicated something and someone else just comes along and says, "Why not just do it this way?"  😉
Bill
CLD
(Mid-Level minion.)
(3,628 Views)
Hi I know that this topic is closed. I’m trying to programme the kj lesker ion gauge 354 and I’m not able to do it. Could you provide me you Vi? Thanksss
(414 Views)
