Custom control decal not clickable
I created a custom Boolean button by adding a decal (Boolean glyph). When I attempt to operate the button on my front panel by clicking on the decal, nothing happens. If I click outside the bounds of the decal, the button does operate as expected. What's up?
Message 1 of 10
(5,469 Views)
Can you send us the example of you button so we can test it?
Benoit
Benoit Séguin
Software Designer
Message 2 of 10
(5,461 Views)
Attached ctl
Message 3 of 10
(5,446 Views)
I dont know why, but when I'm creating one, everything is working fine. I try yours,  and it doesn't work.
Can you send me your picture I will creat it for you and send it to you back
Benoit
Benoit Séguin
Software Designer
Message 4 of 10
(5,441 Views)
I think I know what the problem was.  If you use the Control Editor in the "tweezer" mode, and move all the parts around, you'll see that there are actually two folder images...one of them was buried under the button.  I think that one is the decal.  I think the other one is just an image, which, as we now know, doesn't let you change the button state when it's sitting on top of the button.  I removed the image (so that only the decal was left), and brought the decal to the front (using the "Bring Forward" under the Reorder toolbar button).  After I did this, the button was clickable over the image.  I have attached a "fixed" version of the original control here.
Hope this helps,
-D
Message 5 of 10
(5,433 Views)
You are absolutely right. I reopen it, and I found exactly the same thing.
You solve it.
Benoit
Benoit Séguin
Software Designer
Message 6 of 10
(5,413 Views)
Thanks, Darren. Great troubleshooting. I don't do a lot of custom controls.
A related question for you: My decal has a gray background around the folder glyph. Do you know if its possible to make those pixels transparent so the button is visible there?
Message 7 of 10
(5,403 Views)
Hi Ron,
Looks like you're encountering all the same issues that I did when making some custom buttons a while back.  🙂  I think you need to mask the gray part of your image as transparent in your image editor, then paste the image with the transparent background as your decal.  Whenever I've needed to create a transparent mask on an image, I've used Microsoft Photo Editor (it's included in Office XP and previous, but you have to explicitly select it under the "Additional Office Tools" component during the Office XP install).  There's a button on the toolbar in Photo Editor that lets you assign a transparency mask.  If you don't have Photo Editor, I'm not sure how you would do it in another image editor.  I was really disappointed when Photo Editor was removed in Office 2003.
Good luck,
-D
P.S. - If there's an easier way to make those pixels transparent, I hope somebody else posts with more information.
Message 8 of 10
(5,399 Views)
OpenG includes a package with some buttons, including a folder button, and I think it might be transparent. Even if it isn't, they have some very useful tools.
___________________
Try to take over the world!
Message 9 of 10
(5,381 Views)
Didn't think to look there. Just what I needed.Smiley Very Happy The decal background is indeed transparent.
Message 10 of 10
(5,371 Views)
