Custom error code conflict
How should error code conflicts be resolved?
Imagine that I have installed two VI packages that happen to have overlapping error ranges for their custom errors. How are the overlapping errors resolved?
The LabVIEW help says that this is already the case. The example given is error code 65. However, the help does not give any indication how to resolve this. It links to an empty page in the knowledge base.
Lars Melander
Uppsala Database Laboratory, Uppsala University
(3,782 Views)
This link tells you the range of error code that you can use for custom error codes, if you stick to that, the chance you of overlap will be reduced.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,771 Views)
Yes, I know that. That was not my question. My question was: how are conflicts resolved, once they appear?
The LabVIEW help already mentions at least one existing conflict.
Lars Melander
(3,760 Views)
Sorry... I think that o resolve such conflicts you need to change one of the two ranges, which means you need to have acces to the code of at least one of them to change the error range you are using.
Epictetus
Antoine Chalons
(3,758 Views)
When LabVIEW does the lookup, it reports both solutions already.  So I'm not understanding what your issue is.
(3,746 Views)
OK, I did not know that. Thank you.
Lars Melander
(3,744 Views)
