Custom errors: is there a way to make Error Code Editor read a file inside the project directory?
I'm trying to use the Error Code Editor tool ("Tools > Advanced > Edit Error Codes...") to create a CustomFile-errors.txt file inside "My Project directory", i.e., outside user.lib
Is this possible?
Notes:
1. The "CustomFile-errors.txt" is inside the project directory "...\project\erros\CustomFile-errors.txt"
2. When executing the main.vi inside the directory "CustomErrors (vi)" in LabVIEW, the custom error text isn't displayed... unless the file "CustomFile-errors.txt" is placed inside user.lib
Error undefined when *-errors.txt is outside user.libError undefined when *-errors.txt is outside user.lib
3. When executing the .exe file inside "CustomErrors (application)" the custom error message is displayed normally
4. The .zip files have an example of what I'm trying to do
The custom error message is displayed normally with the .exe fileThe custom error message is displayed normally with the .exe file
(1,803 Views)
Accepted by topic author mthheitor
Is this possible?
I don't think so:
Make custom error code files part of a project - NI Community
Project error code files ... - NI Community
(1,762 Views)
