Custom express VI gives "unable to view properties" error
It seems like any time I open a custom express VI by:
  • Right click block diagram
  • Select VI...
  • Browse to non underscorred LLB outside of ProgramFiles/LabVIEW
  • Select TestExpress Source
  • Drop on block diagram
I get the "Unable to view properties" error. I'd like to keep the express VI outside of the ProgramFiles/LabVIEW folder to keep all the code in one place.
FYI: LV2015SP1
(3,525 Views)
Hi nanocyte,
Are you able to view the properties if you keep the Express VI inside the Program Files/LabVIEW folder?
G-IV
(3,488 Views)
Yes, the config VI pops up if I put it in the user.lib folder. You can try it for yourself if you'd like. I attached the express VI.
(3,464 Views)
Hi nanocyte,
It looks like the any Express VIs that you create have to be in the LabVIEW directory, so I don't think you are going to be able to keep these in the same place.  I found this excerpt:
"Place the Express VI in the LabVIEW directory structure."
It's located on page 9 of the LabVIEW Express VI Development Toolkit User Guide. (I have the link set up to open in a new page).
G-IV
(3,458 Views)
