Custom file name when saving
When my program creates a report, I want to save it as a serial number defined in the report.  I want to use the MS Office Report Express VI to do this but unfortunately it only allows you to save the file name as a time/date and/or incremental number.
(5,039 Views)
You can pass in the file name that you want to save the data to.  Why not build up your own file path?  The Build Path primitive will be helpful here.
(5,038 Views)
Unfortunately you cannot input a path to the MS office express VI... 😞 Otherwise I would use the build path function.
(5,034 Views)
Check again.  There should be a path input (at least it is there on my machine).
(4,987 Views)
Hi jiliu317,
  Please check the Configure Options of MS Office Report Express VI ,you will find a "Report Destination" set it to save to file,then you will find "Configure file save options" button will be highlighted and enabled.Press it and you will find many options including file name..
SrikrishnaNF
Srikrishna
(4,978 Views)
