Custom llb icon in user.lib
I have an LLB with a set of VIs that perform a set of routines I use in multiple apps.  I have added the llb to my user.lib.  Is there a way of creating a custom icon for this?  I would like to avoid using the default icon and have an easily identifiable icon (to me) for the group.  I have several other groups that I would like to do the same with.
Bob
(3,749 Views)
I think you can do this with the VI Package Manager from JKI Soft.  I haven't done it myself but am planning on doing it this weekend.
(3,748 Views)
Accepted by topic author rvc
Hi Bob,
no need for a package manager, you may use the built-in icon editor to do your job!
In LV7.1 you go:
-Tools menu -> advanced -> edit palette views
-navigate to the sub-palette icon
-right-click -> edit submenu icon
In LV8+ you may need a different menu item to start palette editing...
Message Edited by GerdW on 03-31-2009 07:50 PM
(3,742 Views)
You may also want to rethink your use of an llb to store VIs that you are developing (as opposed to deployment). A single corrupt VI in an llb will make the entire llb unreadable and an llb is not very compatible with source code control. Save the VIs in a folder or put them in a lvlib.
(3,736 Views)
