Custom palette LV86 to LV2009
I created a custom palette in LV86 by following the step in this KB How Can I Distribute a Custom LabVIEW Palette from My Computer to Others.  Everything is fine in LV86.
On the same computer, I copied the directory Exaprom from:
     C:\Program Files\National Instruments\LabVIEW 8.6\vi.lib\
     to
     C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\
I copied also the file exaprompdf.mnu from
     C:\Program Files\National Instruments\LabVIEW 8.6\menus\Categories\Programming\
     to
     C:\Program Files\National Instruments\LabVIEW 2009\menus\Categories\Programming\
When I start LV2009, one link is missing.  The path of this VI is:
     C:\Program Files\National Instruments\LabVIEW 2009\user.lib\Exaprom PDF\VIs\Text\Set Default Font.vi
     instead of
     C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Exaprom\Exaprom PDF\VIs\Text\Set Default Font.vi
Previously, this toolkit was located in the user.lib, maybe I forgot to delete something?
(2,592 Views)
I am ashamed...Smiley Sad
The link for the file "Document.mnu" is the problem.
I lost 3 hours with this!
(2,579 Views)
