Custom run-time menu file history
Hi all,
I would like my custom run-time menu to contain a history of data files that have recently been opened.
Can you modify the run-time menu at run-time?
Or can someone point me to an existing solution?
Many thanks,
Phill
(3,628 Views)
For your first question check this example: Programmatically Load Custom Run-Time Menu: https://decibel.ni.com/content/docs/DOC-9341
uday
(3,622 Views)
I hope its not available by default. but can be done by custom code which will save the recently opened files in a history file. the same file can be used to retrive the history of data when needed.
If its available by default i am happy to hear from other users.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,622 Views)
Thanks for the reply, but I don't want to load a complete new menu.
I just want to change the items in it.
For example after opening several data files the menu should look something like:
File
Open..
Recent >
   File 1
   File 2
   File 3
Exit
As I reach a limit of say 5 recent files the oldest is removed:
File
Open...
Recent >
   File 2
   File 3
   File 4
   File 5
   File 6
Selecting a historic file will save me from browsing to file path again when I want to releoad it.
Phill
(3,614 Views)
Accepted by topic author tadders
Refer the examples regarding Menu
Navigate to  Help --> Find Examples---> in the search type Menu and select Customozing the menu bar
The above example is for removing the menu item, like the same you can use for adding the Menu and deleting when exceeds after five items as mnetioned by you.
(3,609 Views)
Excellent - thank you!
(3,597 Views)
