Custom sensor
Hello, Guys
I would like to know how do I create a custom temperature sensor (I see only a selected few types on the internet) So how do create a temperature sensor (or multiple types) in LabVIEW. Your assistance is greatly valued. I would like to have more flexibility in the temperature sensor domain
(2,076 Views)
Hi Jaco,
LabVIEW is a programming language. You cannot create hardware ("temperature sensor") using only software…
What exactly do you want to achieve?
(2,070 Views)
To add support APIs for a custom sensor, you need the following,
  • Know the protocol to communicate with the sensor
    • Register to read/write
  • APIs to communicate using the protocol
  • How to convert the digital data into temperature units
  • Wrap up all the above into a VI - you've added support for a new sensor
From the image, it looks like you're using some kind of LINX with Arduino
Santhosh
Soliton Technologies
(2,053 Views)
Most sensors output a voltage that is proportional to whatever they are measuring.
Use the Analog Read vi and scale the output to whatever units are appropriate.
Then you can wrap that up in a VI to use later.
=== Engineer Ambiguously ===
(2,049 Views)
