Customizable Labview Interface
any suggestions on how to make this kind of interface for data acquisition module?
It should ask me how many channels I want to select, then what kind od view do I want (waveform/real-time values or RMS values/or both with waveforms and numeric values), and then the interface should split screen into for example 2 sections if I want to have waveform on one side, and numeric value on other side.
Any ideas?
Message 1 of 9
(6,575 Views)
Yes.  Spend the time to learn LabVIEW (by taking at least Basic 1 and 2).  You should then be able to (a) have your program pop up a Dialog Box that asks the "Front Panel Design" questions that you pose, then (b) have your Front Panel show the elements that you chose.  There are several methods of doing this, including having separate sub-VIs for each option (with an appropriately-designed Front Panel) and simply running the sub-VI that's appropriate.
But once you've worked with LabVIEW and understand how it works and what the various (complementary) ways there are of doing things, you'll be able to make an informed decision about what would work best (or better) in your particular situation.
Bob Schor
Message 2 of 9
(6,564 Views)
For dynamic channel selection examples for DAQmx, have a look at the built-in examples in LabVIEW (via Help, Examples, Hardware input/output, DAQmx, Voltage-Continuous Input). Some more advanced examples you can see if you go via the "Create Project" menu, and you select the "Continuous Measurement and Logging (NI-DAQmx)".
Question about the GUI: If you want real flexibility, use subPanels, so you can dynamically load a Front Panel of any subVI. Some links for more details:
http://digital.ni.com/public.nsf/allkb/D587067E18E0E70186256D44007B91FE
http://www.notatamelion.com/2015/02/02/modularization-its-not-just-for-block-diagrams-any-more/
Message 3 of 9
(6,563 Views)
Thanks to both of you. What would it be LabVIEW Basic 1 and 2? Where I can find that?
Message 4 of 9
(6,478 Views)
Hi vedran,
www.learnni.com
Or check your user account. Do you have an active SSP?
Message 5 of 9
(6,476 Views)
I don't have SSP.
Message 6 of 9
(6,469 Views)
It is called Core 1-2, not "Base".
You do not have licence? Then how do you use LabVIEW? Are you a student? When you installed LabVIEW, where did you get your activation serial from? Students also have the right to access the self learning center on NI.com.
Message 7 of 9
(6,462 Views)
I am a student, and I have evaluation period to use downloaded LabVIEW program.
Message 8 of 9
(6,433 Views)
Message 9 of 9
(6,428 Views)
