Customize Boolean Button Size
The resizing's method for boolean button that I knew is using mouse control.
But in this way it's very hard to have all the button have the same size.
In the Labwindow they have dialoge box that allow user to define the actual
size as number. So I expect that Labview should have too but I can't find
it anywhere in the s/w.
Does anyone has an idea about this?
Do they allow me to spicific the size of boolean button as number?
Thank you very much for all help in advance.
(3,039 Views)
You can resize any control on your front panel by using an attribute node
in Labview 5.x or a property node in Labview 6. You can enter a number for
width and hieght.
"seree" wrote:
>>The resizing's method for boolean button that I knew is using mouse control.>But
in this way it's very hard to have all the button have the same size.>In
the Labwindow they have dialoge box that allow user to define the actual>size
as number. So I expect that Labview should have too but I can't find>it anywhere
in the s/w. >Does anyone has an idea about this?>Do they allow me to spicific
the size of boolean button as number?>Thank you very much for all help in
advance.
(3,039 Views)
