Customize "TestStand UI Button control" in LabVIEW
Dear All,
I am trying to customize the TestStand operator interface as required for our project.  When trying so, I tried to customize the TestStand UI Button.ctl to import pictures on the button to improve the look&feel effects of the GUI.  But I couldnt find options to import the clipboard picture on this control as we could do for normal system/modern button controls in LabVIEW.
Could anyone please let me know how to import pictures (Customize) the TestStand UI button.ctl in LabVIEW.
Thanks in Advance.
Best Regards,
Sathish kumar D
(2,769 Views)
Sathish,
the TS visible controls are ActiveX container. So there is nothing you can customize on the control itself.
You can use properties of the Button control to define an image.
Norbert
EDIT: This question refers more to TestStand rather than LV. I hope that you are aware of the fact that there is also a specific TestStand discussion forum. So for the future please post in the correct forum.
Norbert
Expert: Geometry
(2,764 Views)
