Customized button with image turns black
Hi
I have a small but strange problem I cant figure out. I have customized a button control by importing a GIF-image on top of it just to get a better looking GUI. The problem is that after a while this image disappears and the button turns black. If I reopen the VI the button is OK for a while before it turns black again. This happens both with VI and exe-file. I have searched forum and found one with similar problem but it did not really give a fix to my problem (it involved a lot of reinstallation which I'm not willing to do at the moment).
For info I put the image on top the button by choosing " Import from file at same size" in Custom Control window.
Hope somebody have a quick fix for this "bug" or else I have to revert to standard text button.
Regards
Bård
(3,261 Views)
can you post your control for me to look at? I have a lot of custom controls and I never have this problem. Also include the pictures that you are using for this button.
Tim
GHSP
(3,247 Views)
Here they are.I included an image of the black controls as well as the actual controls so you can make a testvi.
(3,235 Views)
I have exactly the same problem.
Do you have a solution?
Olivier.
(3,073 Views)
Olivier.
(3,073 Views)
