Cut text using event structure
Hi everyone.
I'm making a project with LV Student E. 7.1.1. I have an event structure, its function is scanning a value change in a "control text". Any change in the control text is detected by the event structure, except when I CUT the text (selecting part of the text and presing CTRL+X). The NEW VALUE isn't detected!!! Somebody knows why?
(2,666 Views)
It works if Update Value while Typing is not checked, provided you change the focus after the cut. But then you do not get events for each character as entered.
It works as you would expect in LV8.
Lynn
(2,659 Views)
