Cut waveform measurement
Hi Team,
I trying to end my project which is going to measure the pulsed parameters of magnetic fields. Everything is done (I guess) but I have problem with one group of measurements. I successfully done the cutting of the original waveform (between cursors) and tranfer it to the second waveform like You can see below:
OriginalOriginalCutCut
On first measurements are good, but I don't know how to do correctly on cut (secon one)... whatever I do is the same like on original waveform, I want it to show measurements of this second cut waveform... is it possible?
Thank You,
Mateusz
(3,086 Views)
Hi Matipa,
No, not at all.
Your VI needs a lot of work to "end the project"…
Yes, that's possible.
When you want to calculate data from the "cutted" waveform then you need to cut the waveform data (aka get a subset of the data)!
Right now all you do is changing the x axis of that 2nd graph to show just a part of the full waveform…
On your VI: It's a mess!
(3,059 Views)
Thank you for your fast answer!
I know it's not perfect but i still learning 😕
Like i thought i change only scale of this original waveform 😕
Can you explain me how to cut the waveform data you told?
(3,049 Views)
Hi Matipa,
Open the waveform functions palette. There you will find a function to get a subset of a waveform.
(You may look inside this function: in the end it's just an ArraySubset function.)
(3,045 Views)
Okay, I will try ofc.
Will you tell me what else can I do to make this program more transparent and done correctly?
(3,041 Views)
Hi Matipa,
Implement a statemachine.
Use event structures instead of polling user input at 50Hz loops.
No need for two loops when both handle user input at the same rate.
To summarize: realize a proper structure in your code!
(3,033 Views)
I am probably still too little experienced to comprehend everything like this state machine or changes in input, but loops are already changed :).
Thank You
(3,029 Views)
